-   -   change a crank rod bearing drop oil pan (https://blazerforum.com/forum/engine-transmission-35/change-crank-rod-bearing-drop-oil-pan-29666/)
djramsay 04-13-2009 10:07 PM
hello i have a 1988 s10 blazer 1st gen i look around and could not find out if it can be done can you tell me thanks for your time
bandidolenny 04-14-2009 02:49 AM
Yes, it is possible to change a crank bearing with the crank still in place. You gotta loosen all main cap bolts and remove the one for the bearing in question. Then "roll" out the top portion of the bearing. I am not sure why you are doing this but I am guessing the engine is probaly not gonna live much longer.
djramsay 04-14-2009 05:24 PM
the eng still in the truck can i change it like that??
swartlkk 04-14-2009 07:47 PM
If you can get the pan off, you can replace the crank bearings. I would never take such a short cut unless it was an emergency...
GABlazer 04-14-2009 07:57 PM
If the bearing in question came apart better just tear her down and save yourself some pain down the road....and not far down the road. Bearing less rods tend to eat a lot :)
djramsay 04-14-2009 10:56 PM
but on my 1988 blazer can you pull the pan off when its in the truck still
GABlazer 04-15-2009 06:12 PM
Yeah u can drop the pan witht the engine still in the truck its just better to remove it and do a complete tear down
djramsay 04-15-2009 10:40 PM
ok thank
smdepew1976 04-27-2009 10:52 PM
whatever one is trying to tell you is that if one is needing replaced then the others surely do too........ and the rod and cam bearings.........as well as half dozen other items...might as well leave it broke
