-   -   Changing Valve Cover 98 Blazer passenger side (https://blazerforum.com/forum/engine-transmission-35/changing-valve-cover-98-blazer-passenger-side-78426/)
Ash's Blazer 04-05-2013 10:49 PM
- Any advice?
- About how long?
- Will I be able to change out drivers side valve cover while I have it torn down, or is that just another 3 hours?
Thanks,
G
s10driver 04-06-2013 10:46 AM
loosen the alternator and swing it up ( leave the one bolt still on) move all the harness out of the way and spark plug wires, remove valve cover and clean and install new seal/gasket,reverse procedure. as for the driver side, you will have to slide the power steering pump/AC compressor bracket away from the engine. or get a dremel or cut off tool and cut the back of the bracket to clear the valve cover. I've done it in less than an hour.
