-   -   Chevy blazer engine prob need help asap (https://blazerforum.com/forum/engine-transmission-35/chevy-blazer-engine-prob-need-help-asap-67707/)
filoblazer 02-06-2012 12:38 AM
Hey guys my trunk not looking to good. Today I was driving suddenly the revs were going up and down and it died. Started it no prob but after a few seconds it back fires rev still going up and down and dies on me. Any idea what's the problem.
Chuk Rhodes 02-06-2012 01:48 AM
Is the check engine light on? If so can you read the codes?
filoblazer 02-06-2012 04:05 AM
The Engine light is on. It sometimes blinks. Will let u know Once I get the code
Chuk Rhodes 02-06-2012 04:21 AM
Fairly sure blinking means there is a new code. Thats fairly good, as it usually points you in the right direction. Start with the first / lowest number, fix that before worrying about others.
filoblazer 02-06-2012 05:53 AM
Thanks for that info. Hopefully Tomz I'll find the code
filoblazer 03-14-2012 02:15 AM
Found the problem it's the whole distributor needs replacing I think. I pulled the cap off and the rotor was stuffed. Is the shaft on the dizzy suppose to move around or be solid? Cuz it's kinda loose. One more think are all distributor of a blazer 99 to 01 model all the same?
pettyfog 03-14-2012 05:57 AM
You're correct.. should be no wobble, little spin available.
Best way to find that out is to look up other year model part # and compare them to yours.
Rockauto{dot}com does one better; click on the part number and it shows all models with same fit.
filoblazer 03-17-2012 06:18 AM
Distributor replaced and now car is running good :)
