Chirping sound from bellhousing area
I have a 2002 4WD Blazer with 120,000 miles on it. I'm the second owner and it has gotten excellent maintenance.
The problem that I can't solve is: After driving for about 15 minutes it begins a loud chirping from the area of the bellhousing. It's a constant harminic wheather i'm driving or stopped. wheather I increase RPM or idle, in fwd-neut-or reverse, in 4WD or 2WD. I've changed fluids and filters. I've had it on a lift and verified that the sound is coming from the lower end of the drive train. Any ideas would be greatly appreciated, it's driving me nuts. :icon_shrug: |
while it was on the hoist, did anybody drop the torque converter cover, and inspect all of the flex-plate? i came across a very similar situation on my best friend's Dad Astro van.
turned out to be a cracked flex-plate. you'll probably need to unbolt the TC, and slide it back, so you can properly inspect the flex-plate. |
| All times are GMT -5. The time now is 11:49 AM. |
