-   -   Code Guys please help (https://blazerforum.com/forum/engine-transmission-35/code-guys-please-help-27654/)
newguy07 02-16-2009 05:28 PM
Just had the 1995 Chevrolet Blazer put on a computer at a local shop because it is missing and stumbly. I put on new plugs, wires, distributor cap and rotor. It sill misses like crazy and dies.
It threw one code. P1406
c0a8l0v6i8n9 02-16-2009 06:11 PM
RE: Code Guys please help
It's the EGR, probably has some carbon build up in it. I would take it off and clean it out. Use the search to find a how to on how to remove and clean it.
newguy07 02-16-2009 06:21 PM
How to you get to the EGR? I could get the bottom right bolt out ( fell down in the engine I will deal with that lol ) but I cant get to the left bolt at all. I tried a socket and ratchet and even a wrench but cant get to it.
I found alot of posts on how to clean it but none on how to get that dang bolt out
c0a8l0v6i8n9 02-16-2009 06:31 PM
I dont have your version of the blazer but whats blocking it? try removing the belt the tensioner may be in the way
newguy07 02-16-2009 06:53 PM
yeah the belt, tensioner, and ac are in the way. Its 40 degrees and dark so it will have to wait for tomorrow. I have to pick up an egr gasket anyway.
c0a8l0v6i8n9 02-16-2009 06:55 PM
I had to get at mine with a swiveling extension, but when you get the gasket grab the one with the screen in it to help prevent this problem from happening down the road. Let us know how everything goes. Goodluck.
newguy07 02-16-2009 06:58 PM
yeah I have read about that gasket, does autozone have them?
c0a8l0v6i8n9 02-16-2009 07:00 PM
yea they do its Tomco / Klean Screen EGR Gasket Kit
http://www.autozone.com/R,108452/veh...ductDetail.htm
newguy07 02-16-2009 07:01 PM
Hey thanks, I will pick it up tomorrow
swartlkk 02-16-2009 08:13 PM
Please do not double post your problems. I have removed the references to this code from your previous thread. You, as the author have the right to take a thread in whatever direction you please, but do not ask the same question in multiple locations.
