-   -   code p0305 (https://blazerforum.com/forum/engine-transmission-35/code-p0305-56295/)
gregl316 03-07-2011 03:10 PM
code p0305
I know the code is misfire cylinder 5. The plugs are new the wires are new and the cap and rotor is new. Even being new I check them any how. The plug was carbon-ed up bad so I replaced it. The wire was check for resistance and it checked out good. The cap was checked and it checked out good. Now I'm lost. What else should I check. By the way the compression is 125. I look forward to your responses.
