cold starting issue
cold starting issue
Hello my 2000 Blazer wont start when cold. We did all the reg tune up stuff plugs,cap,wires. It starts great if I leave inside heated garage. We checked fuel pressure readings when it was warmish held around 60psi all night. We checked the pressure this morning
-10c outside it is also was at 60psi when key is in on position but falls of to 45psi when you startcranking motor over. It did start after a few tryspressure ran at 55psi when running. We are thinking of replacing fuel pump should cranking pressure be greater then 45 psi when engine is cranking over?
Thanks Jamie
Thanks Jamie
RE: cold starting issue
I read all that. Im still wondering what the presure would read during cranking-45psi seems low? I didnt really see that in the other thread Thanks Jamie
Second sentence from the link above... The pressure should never drop below 55psi per the book.
Unfortunately, the internet filters here at work don't let me view the diagnostic charts in the post, so I am unable to answer your question right now.
Hey Kyle Thanks I didnt see that. Im thinking we will replace the fuel pump its the original. Jamie
dougg01
01-05-2010 03:47 PM
ravenhurst
15
04-26-2009 07:53 AM
as2higpark
10-18-2007 12:18 PM
