confused
confused
Hello, I have a '99 Blazer 4x4 with a 4.3l. It has 170k miles on it. Here's my trouble: engine is sluggush, it surges or misses going uphill/ under a load & my fuel consumption is terrible.
There are no codes stored.
I have a '98 blazer 4.3l with 310k & it runs way btr than the '99. Any ideas or suggestions please?
Start with a fuel pressure and leak down test. It sounds like you may have a leak in your fuel spider somewhere. Also look through the throttle body into the plenum and see if there are any washed out spots generally it tends to be toward the rear driver side but not always.
not getting anywhere
So far I have changed the throttle position sensor, ignition coil, air filter, idle air control sensor & mass air flow sensor. it STILL feels horribly sluggish/ no power uphill, it almost feels/.sounds like it's got a few dead spots in the throttle ( step on the gas & NOTHING happens for a couple-3 seconds.
thus vortec is NOT impressing me at all. My '98 has 310k miles on it & it was fast as hell & unlimited power.
Another thing worth checking is the catalytic converter. It isn't that difficult to pull one of the upstream sensors (remove it from the exhaust and disconnect it from the wiring harness). It's basically a free test as it takes only time (unless you break something in the process). This will leave the O2 sensor port open to allow exhaust gasses to bypass the catalytic converter. An open exhaust leak like this will be loud.
If it runs better with the sensor out, then the catalytic converter is clogged. If there is no change other than the noise level, then the catalytic converter likely isn't the cause of your issues.
This will set a code for the O2 sensor, but that code should go away when you reinstall the sensor.
I changed that yesterday. I've almost come to then conclusion that it's missing ( low compression in a hole, bad injector etc, etc. That would explainyour poor milege, no power etc. Any ideas?
