Confused about boost valve and reverse boost valve
Old Mar 25, 2012 | 11:52 AM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Confused about boost valve and reverse boost valve
Reverse is slipping. New clutches were installed not to long ago. Fluid dark but not really dark. I tried the Lucas and no help. I don't have a line pressure gauge to test pressures. Where is the reverse boost valve or is the boost valve also called the reverse boost valve? I can take the clip off the EPC and remove it, however there is a clip holding the pins in and it is installed between the valve body and the separator plate. Should the clip be there at all? Would it help the slipping situation to remove the check ball from the capsule at the rear under the separator plate?
http://i1137.photobucket.com/albums/.../Valvebody.jpg
bigdaddykane93
Dec 16, 2010 04:28 PM
Dakota_Don
Apr 28, 2010 02:09 PM
CH@Dbee
Dec 28, 2009 02:37 PM
98s10blazer
Performance & Brainstorming
Dec 18, 2008 10:46 PM
ivannj
Feb 11, 2006 05:38 PM
