coolant leak
Old Oct 15, 2008 | 06:32 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
Default coolant leak
i have coolant leaking from my upper rad hose right where it connects to the top of the rad. i thought it was a bad hose cause it was pretty ****ty but i bought a new one and put it on and the same thing. it seems as if the rad is blocked or something and it has nowhere to go except to squeeze out in a rather steady pace. any thoughts???
Old Oct 15, 2008 | 08:03 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: coolant leak
Are you sure the clamps are still good?
Old Oct 15, 2008 | 11:19 PM
rogggg1020's Avatar
rogggg1020 is an unknown quantity at this point
and dont forget to make sure where it connects theres no build up and pieces of stuff that would make it leak around
Old Oct 16, 2008 | 12:30 AM
vin791's Avatar
vin791 is an unknown quantity at this point
also the stud you hook the hose up to may be loose. i had to remove my radiator dude to the wreck and in pulling one of the hoses off the stud pulled out with it. ergo, yours might be loose too.
Old Oct 16, 2008 | 04:02 PM
ptg327's Avatar
no build up and the hose and clamp are fine. wtf?
Old Oct 16, 2008 | 06:08 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
i had one that the hose clamp had been tightened too tightly and cracked the plastic rad... take the hose off and inspect the area for hair line cracks.....
Old Oct 17, 2008 | 04:57 PM
ptg327's Avatar
I believe it was a small crack because the plastic broke off in my hand. why would it have to be plastic?there goes $200 i don't have
Old Oct 17, 2008 | 08:13 PM
you can get the plastic tank with gasket online for $80 - someone chime in with the gm parts link before I can go find it...
EDIT: found it:
http://catalog.oehq.com/RenderScript...linktype=links
Inlet tank is $46 and outlet tank $71, each with a gasket, for the '93 vin W. I don't know what yours is, though.
Old Oct 19, 2008 | 09:33 AM
ptg327's Avatar
and how does this help
Old Oct 19, 2008 | 09:47 AM
Instead of paying $200 for a radiator, you can spend less on a replacement plastic side tank and do it yourself.
But that's up to you.
