Coolant leak
Old Aug 23, 2013 | 05:27 PM
Jlhazen's Avatar
Jlhazen is on a distinguished road
Angry Coolant leak
I have a 96 blazer that is leaking coolant from somewhere in the back of the engine. When I tried burping the coolant system the coolant was leaking under the car from around the transmission. I have replaced the water pump and the t-stat. Any help?
Old Aug 23, 2013 | 05:52 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
The 4.3 is notorious for the intake leaking. It leaks out around the base on the intake and dribbles down the back of the block.
Old Aug 23, 2013 | 06:02 PM
Jlhazen's Avatar
Thanks for the advice ill have to check it out
Old Aug 24, 2013 | 06:09 PM
BlackBeauty43's Avatar
BlackBeauty43 is on a distinguished road
Sounds like an intake manafold gasket repair. I did this repair twice. I posted a thread about the procedure and tips if you want to do it yourself! Check it out
Old Aug 28, 2013 | 07:16 PM
eisterd's Avatar
eisterd is on a distinguished road
check the steel tube that connects to the intake for the heater. The plastic retainer and rubber in there could be shot....it's a popular place to leak
Old Sep 2, 2013 | 08:29 PM
Jlhazen's Avatar
Tore down and replaced the intake manifold gasket. Had a little trouble getting the distributor timing right but when I did it fired right up. No leak and she runs between 194 and 198/199 when hot. Thanks for the help.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
dashyman
Jun 4, 2006 11:21 PM
edacsac
Feb 10, 2006 06:04 PM
