coolant problem
Alright stuck scratching my head on this one.
I have a 2004 chevy blazer 2 door 4x4 4.3V6 I had the issue of running hot when I was idling so after flushing the radiator and replacing the thermostat a while back I bought a new radiator. Also I had the issue that when I would shut my blazer off the engine temperature would increase to 220 or 230. Not sure why this is the case. I decided to replace the radiator last week. Now at idle I am running cool but at speed of 65 - 70 i am warming up past 210. Not sure why this is happening. Also I am still having the issue with my engine temperature increasing when i turn it off. Any ideas? |
air in the cooling system?
Originally Posted by jpimp
(Post 630588)
Your temp increases when you shut off your blazer because the flow of coolant stops. Restart it, and you will see the temp start falling after the coolant starts circulating again.
Originally Posted by Biggboy
(Post 630839)
Also my temperature runs at 200 but once I turn my air on the temperature shoots to 210+ and I can never get it to cool back down again until i leave the engine off for some time. Not sure whats causing this. |
Is this with the dummy gauge on the dash. They can unaccurate
Originally Posted by newguy
(Post 630884)
The coolant mainly gets hot when the air is turned on and I am at high speeds. |
How long did you burp the system for? I had a similar issue with air in the system and ended up burping it and also holding it at 2k rpm for a few minutes to make sure all air was out of the system. Is there any leaking at all?
Originally Posted by fletch125
(Post 630971)
When I do get hot I do smell some coolant but I dont see any leaking. I am to the point where I am going to try and have the water pump and fan clutch replaced just to try and fix it. |
