elfman231 |
09-26-2020 01:56 AM |
Crank Position Sensor
Ok, so I’ve got a 1997 Blazer and, very long story short, the timing chain cover leaks like the Exxon Valdez...I’m a weekend warrior when it comes to automotive maintenance, so when I rebuilt the top end of the engine after the lower intake manifold gasket failed, I was unaware of the need to drop the oil pan until I had already removed the old one. I would like to do it correctly now, because my daughter will be driving it. My question is, if I remove the crank sensor in order to change the cover, will I have to do a crank position re-learn? I had to do one when I changed the timing chain because, in swapping the crank sensor to the new cover I broke it, and obviously had to do a re-learn then, but I didn’t know if that was because I had installed a new one or does just removing it require a re-learn...
