-   -   crankshaft position sensor (https://blazerforum.com/forum/engine-transmission-35/crankshaft-position-sensor-14211/)
murfthesurf4 11-05-2007 04:24 PM
[&o] Is the sensor really located in the distributor? 95 4.3. If so, is it easy enough or should I take it somewhere? have a lot of dismantling to do. plenam and all? I know ill f it up
swartlkk 11-05-2007 07:58 PM
RE: crankshaft position sensor
No, the CMP (camshaft position) sensor is located in the distributor body. The CKP (crankshaft position) sensor is located in the front cover of the engine near the harmonic balancer. It should be at the 7 o'clock position when looking directly at the front of the motor.
blazinloud 11-05-2007 10:49 PM
oooooo, the elusive harmonic balancer :DI've heard of it but what exactly is it?
Is it similar to a sky hook? lol ;)
thegr81 11-06-2007 12:29 AM
Swartlkk told me a while ago about the crankshaft positionin sensor, and if I remember correctly he told me to take it to the dealer to have done cause once they replace the old sensor they have to run a reader on it to make sure it matches up to the motor. I know im off on that last part but you want to have the dealer do it!
murfthesurf4 11-06-2007 04:55 AM
:)Thank you ,I was looking all over and I found it while I was looking in my book near the camshaft pully. My book doent list it seperatly but you have to remove it before you take off pully.. Thank you for responding
thegr81 11-06-2007 04:57 AM
No problem, anytime you got a question there's an ear that listens and eye that see's , and help will be there!!! [sm=chattypair.gif]
swartlkk 11-26-2007 11:01 AM
Consolidating all threads into this one...
Other threads to be closed and pointing to the thread above include:
IS IT TRUE?
camshaft position sensor P0300
shaking!!
murfthesurf4 11-26-2007 11:04 AM
:)sorry for all this swartlkk
swartlkk 11-26-2007 11:54 AM
No problem! It happens, but try not to let it happen again!!;) LOL
