crankshaft position sensor
hi, its a 00 blazer 4.3 , just wonderin where the crankshaft position sensor is
RE: crankshaft position sensor
It is located on the passenger side of the front cover slightly behind the harmonic balancer. Looking at the front of the engine, it will be approximately at the 7 o'clock position.
If you are replacing this component, please be aware that a CKP variation learn proceedure will need to be completed. This allows the PCM to precisely calibrate the characteristics of the new sensor to that of the engine for accurate timing control. |
thanks. could you tell me how to do the learn procedure?
here is what my scanner says.... PO339 -- crankshaft position sensor a ckt intermitant--- does that mean i havta replace it? on s10forums some people say they replaced it and didnt have to do the relearn part, others say they did.
ORIGINAL: agent305 here is what my scanner says.... PO339 -- crankshaft position sensor a ckt intermitant--- does that mean i havta replace it? on s10forums some people say they replaced it and didnt have to do the relearn part, others say they did. |
ORIGINAL: agent305 thanks. could you tell me how to do the learn procedure? |
ORIGINAL: cegimonl ORIGINAL: agent305 thanks. could you tell me how to do the learn procedure? |
I did the computer reset unplugging the battery and worked but anyway I will do the learn procedure that you said swartlkk. Just a recommendation, that piece have a screw that does not have to be screw it to tight to avoid the crankshaft hit the sensor making the piece work failure and producing a weird sound.
It may work just fine, but you really will never know until you could potentially have a problem. A CASE learn will save you from spending a lot of money chasing problems later.
| All times are GMT -5. The time now is 05:34 AM. |
