-   -   crankshaft positioner (https://blazerforum.com/forum/engine-transmission-35/crankshaft-positioner-39734/)
coupedeville59 Jan 24, 2010 03:57 PM
having issues cranking 97 blazer when it is raining outside. It will turn over but not crank. When it is dry I only have slight issues. Doing research it looks like I need to replace the crankshaft positioner. Where is it located and how to you replace it?
rriddle3 Jan 24, 2010 04:17 PM
This situation is more commonly associated with the distributor cap. Check it for cracks, carbon tracing, or being loose. I don't know about the '97s, but on some model years there is a small screen on the base plate of the distributor that can get debris on it and moisture will collect there, causing issues.
