-   -   Delayed Engagement? (https://blazerforum.com/forum/engine-transmission-35/delayed-engagement-97035/)
peenar 06-02-2018 05:45 PM
Delayed Engagement?
im pretty sure I have Delayed Engagement. I put it in gear and it takes a couple of seconds to engage.
also when reversing it tends to be a lil more hesitant to go backwards, when it does go backwards it can sometimes make a bit of noise. It goes forward and accelerates just fine.
Transman304 06-03-2018 04:21 AM
Check the fluid level and condition. The backing up and noise may be the issue as that is a common complaint when the rear planetary gears are failing. How many miles on the vehicle?
peenar 06-05-2018 04:14 PM
its got like 200k+ and was parked for like 6 months over the winter.
I checked fluids and topped oil up before attempting to fire it up. ran a lil rough at first but seems to run like it did before it was parked.
Transman304 06-05-2018 07:15 PM
Do you have rust on the brake rotors? Rust in the rear drums?
peenar 06-05-2018 07:23 PM
Yes the obvious rust on the rotors. Probably on the drums. It rolled backwards downhill no problem. After having the ebrake on for the 6 months it was parked.
Transman304 06-05-2018 09:31 PM
I would look at other areas before heading in the direction of transmission. Good luck
