Desperate, broke and not that mechanically inclined :/
Good to know for future reference. And probably something I should have known. Thanks.
So an update:
After going through the suggestions, and starting with taking out the Thermostat, we discovered that it was Frozen shut. So that solved the overheating issue. We flushed the system till it ran clear, but have not put in the Flush cleaner yet. I'm going to run it till saturday with just water and antifreeze to see if more of that gunk gets knocked loose.
Then I'm going to drain it, flush it, drain it again, and use the flush cleaner(couldnt get Peak, az was all out, but I did get some flush cleaner). then drain it again and fill with coolant and water.
Again, thank you everybody!
lowloudnproud1
06-13-2010 01:34 AM
Al3x
03-07-2010 09:49 PM
