Dex cool
Is it safe to mix other coolents with dex cool? I noticed today that im low in coolent, if not I think i'll just flush it all out and replace it, thanks
You could only combine a silcate-free coolant. If they are organic acid technology (OAT) types they should mix okay.
Do not mix Dex-Cool with an ethylene/propylene glycol coolant. If you want to switch to one of those BE SURE to THOROUGHLY flush the system prior to putting it in. |
ok thanks for the info
| All times are GMT -5. The time now is 11:22 AM. |
