-   -   Dexron VI Trans Fluid (Comparability) (https://blazerforum.com/forum/engine-transmission-35/dexron-vi-trans-fluid-comparability-98082/)
ken1953 11-03-2018 09:06 AM
DEXRON®-III Automatic Transmission Fluid. Look for “Approved for the H-Specification” on the label.
My question is it ok to mix old dexron III Fluid with the newer Dexron vI Fluid because I am in need of trans filter and fluid service (Approx 5qts of new fluid) an want to be sure this would not cause a issue with my Trans, since I have absolutely no issues with it and do not want to create any issues. (2005 Blazer LS rear wheel drive 4.3 Auto Trans)
. Thanks in Advance Ken
Transman304 11-03-2018 10:49 AM
No problem what so ever.
G0LFADD1CT 11-03-2018 12:02 PM
I would think if they were not compatible then the manufacturer would not recommend it as a substitute. I've mixed both in the past when I wanted to use what I had left from a previous purchase. Never noticed any difference what so ever in shifting operation.
LesMyer 11-04-2018 12:20 PM
Zero problems
