Did mpfi swap, now i have white smoke
Hey guys so i had what a believed to be a leaky injector so i went ahead and swapped it out for some mpfi ones and now my truck has white smoke till it warms up, and a little bit of blueish white smoke after its warm. I also changed my distributor cap and rotor about 900 kms before this, not sure if i needed to do any timing by replacing the cap and rotor, anyways i also have a blinking cel, little bit of lack of power, and rough idle and acceleraton, maybe i broke a spark plug wire? Its a 1997 gmc jimmy btw thanks :)
Blinking cel means you have a catalyst damaging issue. Ie you're dumping raw fuel (or coolant) out the exhaust. Odds are it's fuel in your case.
A couple things you will want to do: 1. Do a fuel pressure leakdown test. It is possible you got a defective mpfi unit, and one of your injectors is stuck open. If you search, captainhook has an awesome how to for the fuel pressure leakdown test. 2. Run a code scan and find out which cylinder(s) has the misfire. From there you can ohm out your spark plug wires and rule that out. |
Originally Posted by chevyriders
(Post 688328)
Pulled a code, i got p0300 misfire code
I got the p0300 misfire code, i dont know if it is from the previous injectors or the new ones, or the wires, could you send the link to the leakdown test? My search function doesnt work properly
| All times are GMT -5. The time now is 10:08 AM. |
