-   -   Distributor problems (https://blazerforum.com/forum/engine-transmission-35/distributor-problems-99781/)
Mutt5son Jun 21, 2019 07:47 PM
Hello I have a 1996 s10 blazer. That runs good when everything is is right. But I have to replace the distributor every year. Is there anything I can do to correct this? Help!!!
cleburne red Jun 21, 2019 08:14 PM
First, welcome to the forum!
Why are you having to replace the distributor every year? That sounds awful
LesMyer Jun 21, 2019 10:21 PM
Are you using the correct weight of oil? Supposed to be 5W30. Thicker oil can cause excessive wear on the distributor gear.
swartlkk Jun 22, 2019 09:32 AM
Along with what others have asked/suggested, what brand of distributors have you been using?
Have you set the CMP Retard appropriately when installing each new distributor? CMP Retard is a scan tool PID that correlates to the proper alignment of the distributor to the cam which, when set appropriately, will lead to the best distributor gear life.
