Ecm
Physically, it is the same PCM, however the programming is quite a bit different. You could have the PCM reprogrammed to work with a manual transmission, but you would not be able to swap them without the proper programming.
NC93BLAZERLT
16
Jan 4, 2010 11:08 AM
