engine
Old Nov 28, 2012 | 01:18 PM
smethken's Avatar
smethken is on a distinguished road
Default engine
I have a 97 four-wheel blazer when I started it and put it in drive and give it gas it dies on me. Does anybody know what might be causing that?
Old Nov 28, 2012 | 02:30 PM
Diaita's Avatar
could be a lot of things, any more symptoms?
Old Nov 28, 2012 | 02:47 PM
smethken's Avatar
It has no problem idling when I step on the gas it dies
Old Nov 28, 2012 | 03:27 PM
Diaita's Avatar
have you checked all the connections to the air intake? fuel pressure?
Old Nov 28, 2012 | 03:48 PM
smethken's Avatar
My check engine light came on. Po155 Do you think that has anything to do with it
Old Nov 28, 2012 | 04:00 PM
Diaita's Avatar
prolly not a cause, but maybe a symptom of the issue
P0155 Code... - S-10 Forum
Old Nov 29, 2012 | 06:52 AM
rriddle3's Avatar
Better yet, take a look at our own thread.
P0155 Explained
Old Nov 29, 2012 | 08:59 AM
cleburne red's Avatar
Will it idle in gear fine? Also, can you rev up the engine in neutral? Basically, does it die only under load, or any time the throttle is opened?
Old Nov 30, 2012 | 10:59 AM
smethken's Avatar
When I start the car. It revs up to about 3000 by itself and then goes back down and when I put it in drive. It runs for about 3 4 seconds
Old Nov 30, 2012 | 12:28 PM
rriddle3's Avatar
Have you checked the Idle Air Control (IAC) and Throttle Position Sensor (TPS)?
