-   -   engine (https://blazerforum.com/forum/engine-transmission-35/engine-75457/)
smethken Nov 28, 2012 01:18 PM
engine
I have a 97 four-wheel blazer when I started it and put it in drive and give it gas it dies on me. Does anybody know what might be causing that?
Diaita Nov 28, 2012 02:30 PM
could be a lot of things, any more symptoms?
smethken Nov 28, 2012 02:47 PM
It has no problem idling when I step on the gas it dies
Diaita Nov 28, 2012 03:27 PM
have you checked all the connections to the air intake? fuel pressure?
smethken Nov 28, 2012 03:48 PM
My check engine light came on. Po155 Do you think that has anything to do with it
Diaita Nov 28, 2012 04:00 PM
prolly not a cause, but maybe a symptom of the issue
P0155 Code... - S-10 Forum
rriddle3 Nov 29, 2012 06:52 AM
Better yet, take a look at our own thread.
P0155 Explained
cleburne red Nov 29, 2012 08:59 AM
Will it idle in gear fine? Also, can you rev up the engine in neutral? Basically, does it die only under load, or any time the throttle is opened?
smethken Nov 30, 2012 10:59 AM
When I start the car. It revs up to about 3000 by itself and then goes back down and when I put it in drive. It runs for about 3 4 seconds
rriddle3 Nov 30, 2012 12:28 PM
Have you checked the Idle Air Control (IAC) and Throttle Position Sensor (TPS)?
