Engine Bog's
Hi Guys
New to the forum hopefully maybe someone can help i have a 2000 GMC Jimmy 4.3 When i try to accelerate hard the engine bogs, doesn't go no where, i can accelerate normally without any issues. Complete tune has been done, not MAF, Cat has been changed,fuel pressure is fine Any suggestions? |
Originally Posted by Freakshow
(Post 286489)
Hi Guys
vacuum is all good
no service engine lights on |
thats odd. i'd still check all the vacuum lines just to make sure if you havent already. did you check vacuum from the test port? could be a broken hose after the port
