Engine Code P0404
Old Aug 10, 2007 | 11:51 PM
ggwash21's Avatar
ggwash21 is an unknown quantity at this point
Default Engine Code P0404
I'm on my 3rd EGR valve and i'm getting a P0404 and it says erg valve curcuit. and the guys said either bad wire or computer is bad and causing it to think ERG is bad. Has anyone had this issue before? he said its opening the erg when it doesnt need to or vise vursa..
Old Aug 14, 2007 | 10:38 PM
Hanr3's Avatar
Default RE: Engine Code P0404
What year engine?
The EGR is controlled differently over the years.
Could be the solinoid that operates the EGR, if your engine has it.
Old Aug 15, 2007 | 07:07 AM
I'm going to assume since this is an OBD2 code that this is a '96-'02 engine (the mid-'02+ 4.3L don't have a conventional EGR valve as we know them).
If you have carbon buildup that has started to flake off in the EGR supply tube, you could be getting this code due to carbon holding the valve open. I would recommend that you remove and clean the EGR valve. Purchase the revised gasket with an internal screen. Then get a brass pipe cleaner and clean out the lower hole where the EGR valve mounts on the lower intake manifold. Before reinstalling the EGR valve, attempt to start the engine. This will clear any loosened debris from the supply line. Be aware that the engine may race if it does catch due to the large vacuum leak from the missing EGR valve.
Old Aug 15, 2007 | 11:43 PM
ggwash21's Avatar
I have done that and same thing, this is becoming a nightmare.... i'm thinkin about pulling the intake off and having it cleaned out...
Old Aug 16, 2007 | 06:57 AM
The EGR gases are not in the intake for a very long time. There are two short tubes in the lower intake. One leads to the intake plenum, the other leads to the EGR supply tube. If you were going to remove/replace something, I would remove the EGR supply tube first to see if you can't knock any carbon out of it. Crappy part about the EGR supply tube is I think you have to remove the driver's side accessory drive bracket to get to it at the intake and I never have tried to determine where it connects in with the exhaust...
Old Aug 16, 2007 | 12:36 PM
ggwash21's Avatar
i will look. if its a pain in teh **** i will let it be but i plan on tearing into this weekend. since i'm taking off to Utah for elk hunting on the 31st..
Old Aug 16, 2007 | 01:57 PM
Verno's Avatar
Verno will become famous soon enough
ORIGINAL: ggwash21
Sound like a plan, wish Iwas going with ya.
djboyzs
Oct 14, 2013 07:14 PM
DREW SHARP
Mar 19, 2013 07:21 PM
92s10Blzr
Dec 7, 2009 03:12 PM
lostatsea85
Jun 30, 2008 10:06 PM
