-   -   Engine Fan or Electrical Fan (https://blazerforum.com/forum/engine-transmission-35/engine-fan-electrical-fan-101546/)
Viggo 04-22-2020 02:16 PM
Quick question. I have a '71 Blazer with a 454 that overheats when not moving. I'm working on getting it back on the road and want to eliminate this problem. Should I go with an electrical radiator fan in conjunction with the engine fan. Or should I have just the electrical fan? Can the electrical fan be tied the thermostat or will I always have to switch it on? I don't like the idea of having to flip a switch each time I drive it as I know I will forget? Looking forward to your advise!
christine_208 04-22-2020 10:42 PM
I think it is pretty standard set up to have an electric fan with a relay controlled by a temperature sensor.
Does your mechanical fan have a shroud? Adding a shroud can make a big improvement if you want to keep things simple. I learned this lesson on my 68 Mustang.
Viggo 04-23-2020 10:25 AM
Hi there, yes the mechanical has a fan and the blazer still overheats when stuck in traffic.
rriddle3 04-23-2020 11:01 AM
Firstly, what have you done maintenance-wise? Thoroughly flushed the coolant system including the heater core? Installed correct amount of coolant mixture? Replaced the thermostat? Replaced the radiator cap?
Viggo 04-24-2020 10:27 AM
Thermostat was replaced. Never thought about replacing the radiator cap. The cap looked newish. Suppose I can give that a try! Thanks
error_401 04-25-2020 02:25 AM
Check and flush radiator too. There is a reason for overheating. Should not be the case - unless you live in a place that has already 90 - 100 F.
