Sponsored by:
Sponsored by:
engine help
Old 03-16-2008, 03:27 AM
frank29 is an unknown quantity at this point
Default engine help
found some numbers on engine behind valve cover drivers side 10066036. what kind of engine is it sorry its on a 1991 fullsize blazer
Old 03-16-2008, 09:07 AM
Default RE: engine help
It is a Targetmaster/Goodwrench crate 350 which could have either a 2 or 4 bolt main configuration with a 2 peice rear main seal. It is made in mexico.
Alittle research on the internet...
Universal 350 SBC Engine ('71-'85) up to 260hp (LM1) - 5.7L 350CID 8CYL
Brand New Goodwrench 350 Engine 1971-1985 Car and light Truck Replacement Engine.
This engine remains our most popular largest selling crate engine of all times.
This is a great entry level replacement engine for older cars and trucks, and a great basic street rod engine. All of the parts in this engine are Brand New.
350 Cubic inches 4.00" Bore, 3.47" stroke
8.0:1 compression ratio.
250 HP @4300 rpm 350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036 2 piece rear main seal 4 bolt main
Crankshaft- part # 3932444 Nodular Iron 1985 and older flywheel bolt pattern.
Connecting rods- Part # 10108688 Powdered Metal
Pistons- part#12514101 Cast Aluminum
Oil Pump- part # 12555284 G.M. High Volume Pump
Camshaft- Part#3863151 Hydralic Flat tappet
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194° Exhaust Duration @.050"- 202°
Lobe Seperation-112°
This cam Has a mechanical Fuel Pump Lobe. This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808 casting #33417369
1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
7 Bolt style Exhaust Flange Standard 85' and prior intake manifold bolt pattern.
Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
N.alaska_blazer
02-23-2009 01:31 PM
Tony H
12-14-2008 02:04 AM
johinut
10-24-2008 04:06 PM
loppy crimp
09-11-2008 08:31 PM
DBlaser_ca
08-02-2007 04:44 PM
Quick Reply: engine help
