Engine Hesitates when high humidity
Without having a clue as to what you are driving, I will suggest removing the distributor cap and looking at the base plate. If there is a small screen or opening there it can become clogged with debris and trap moisture that can cause the symptoms you've described.
And the SES lite isnt coming on? Bet it is..
Also can be plug wires are worn out. Do the cap rotor wires..Ac Delco is best.
Dont buy cheap, unless you like coming back here and doing humble pie for not listening to us.
Happens over and over. It's embarrassing.
BTW: What did the clutch problem turn out to be?
Cap and rotor! Definately. Just went through this myself. Shoot the wad and buy delphi/ delco. I bought a cheapy wells and got 10k out of them before the crudded up. Talked to a Napa guy and this is a common prob. And GM knows about it.
*UPDATE* After a little research turns out there was no "redesign" Found the TSB that simply says to blow out the vents on the Base of the distributer. Just goes to show you that most parts guys are FOS. And I, unfortunately, got sucked in.
mickey_bigdaddy
May 27, 2015 02:01 PM
fraze936
May 15, 2012 10:32 PM
Caroline Picard
Apr 12, 2011 03:30 PM
thesnowgod
Dec 5, 2007 02:41 PM
