Engine Knocking
Old Jul 19, 2007 | 01:45 PM
oblivous's Avatar
oblivous is an unknown quantity at this point
Default Engine Knocking
I'm not sure if the engine was knocking, but myblazer started jerking and i heard some noise. But it does that periodically.What could be the cause of that.
Old Jul 19, 2007 | 04:31 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
Default RE: Engine Knocking
i have no idea but u need to put some details. what year and model is your blazer? when does it do that? how long/ loud/ harddoes it do that?
Old Jul 19, 2007 | 04:38 PM
oblivous's Avatar
I have a 1989 s10 Chevrolet Blazer 4x4 2.8L V6. It only makes jerks like once every few minutes. No sounds just jerking of the vehicle
Old Jul 19, 2007 | 05:09 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
You still havent given enough info, this could be literally dozens of things based on your description.. ranging from engine/tranny problems to suspension/chassis parts being broken and/or worn.
Unfortunately the 2.8s were pieces of junk to begin with. It could be a misfire, whens the last time it had a tuneup? Plugs, wires, cap&rotor... maybe a vacuum leak could explain why its doing it periodically?
Old Jul 19, 2007 | 06:09 PM
oblivous's Avatar
I have only had it for 4 months. I dont know when it has had its last tune-up. It just jerks makes no noise at all, only jerks once every few minutes. It has a new engine that is no more than 6 years old. So it may just need a tune-up. But what would cause it to jerk. Can you just please give me an idea, so i can get it looked at.
Old Jul 19, 2007 | 06:45 PM
A misfire in one cylinder is enough to make some unGodly shakes and vibrations, but if you aren't mechanically inclined, you may take it to a shop for a more informative diagnosis.
Perhaps you could check the motor mounts?
Old Jul 23, 2007 | 01:20 PM
oblivous's Avatar
I figured out what it was. I was leaking oil through my valve covers underneath my cyclinder heads. I replaced my valve covers and replaced all my spark plugs 4 out of 6 had oil on them because of the leak. Then I replaced the wire set and I also replaced the distrubuitor and the cap. It runs fine, all it needed was a tune-up.
Old Jul 23, 2007 | 07:42 PM
blazinloud's Avatar
I dunno if my 2.8 in my z24 is exactly like a blazers 2.8 but that engine kicked a**. Always started up........thats at -50*C without the block heater plugged in, and it sat alllll night.
breakyadown89
Mar 28, 2010 10:12 AM
ComputerNerdBD
Feb 28, 2010 11:30 AM
rmcf1974
Jun 26, 2009 09:43 PM
scottty56
Dec 30, 2006 04:10 PM
Thebeast92
Nov 18, 2006 11:42 PM
