-   -   engine management light on and................. (https://blazerforum.com/forum/engine-transmission-35/engine-management-light-25157/)
wetdog Nov 26, 2008 12:21 PM
...........surging on idle between 500 and 2000 rpm.
i have no clue, any of you guys got an idea?
regards,
mick.
WolfPack Nov 26, 2008 01:16 PM
RE: engine management light on and.................
Nope. We will after you get the code read though:D
blazere87 Nov 26, 2008 02:02 PM
I would look at the fuel filter. What other hiccups does your blazer have. Any problems accelerating? Do the RPM's change after driving for a while. Any route where gasoline travels you can look at for leaks or maybe even blockage.
wetdog Dec 4, 2008 07:13 AM
cheers guys.
gettin your codes read over here is a costly affair down at the chevvy dealers.
car is runnin ok, but there is a small fluctuation at idle.but, i guess i'll just let it develop :D
mick.
swartlkk Dec 4, 2008 07:24 AM
Sorry that it costs you so much to have the codes read, but that is really the first step to fixing your truck. The truck is trying to tell you what is wrong. You could buy yourself a cheap code reader!
