-   -   Engine not as responsive as it used to be (https://blazerforum.com/forum/engine-transmission-35/engine-not-responsive-used-29925/)
tubgrinder1968 04-23-2009 03:41 PM
i have a stock 1988 blazer 4x4 with 4.3 V6 fuel injection automatic. Its not as responsive when I give it gas anymore and it runs a lot quieter at an idle. Is there anything that can be done besides exhaust to bring it back up to speed.
mikeinwi 04-23-2009 04:36 PM
an exhaust wont bring it back to life, trying doing a tune up, changing the oil, fuel filter and run a can of sea foam through and also change the air filter then you should be good.
tubgrinder1968 04-23-2009 09:24 PM
alright sounds good. I was scratchin my head because it used to run like a charm and had that good "roar" now the past week or so it seems like a different car
okvortec 04-23-2009 10:20 PM
Does that seafoam stuff really work?
mikeinwi 04-23-2009 11:55 PM
alot of guys swear by it, if you do a quick search youll be able to find the steps on how to use it and a ton of testimonials from guys.
