Sponsored by:
Sponsored by:
Engine ping
Old 04-26-2008, 07:17 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Default Engine ping
1995 Blazer 4.3 liter any suggestions on how to get rid of that dreeded engine ping, some say to use higher octane fuel but with prices these days was wondering if anyone had other suggestions.
Thanks
Old 04-27-2008, 01:16 PM
Default RE: Engine ping
What are you burning now?
I am going to guess 87 octane without ethanol.
switch to 89 octane with 10% ethanol. It should cost less then the straight gas and has better octane. Plus the ethanol will clena out your fuel system, that can be good or bad depending on how dirty your fuel system is now.
Old 04-27-2008, 03:34 PM
gscrippler's Avatar
Thanks, was hoping there might be something else CT. gas prices are $3.74 for 87 octane
guess I'll have to go to the 89 octane Any Idea where I might be able to buy an exhaust Y-pipe
From the Manifolsd to the cat for my 1995 Blazer
Old 04-27-2008, 03:57 PM
Did a quick search and turned up this thread (knew I had answered this before):
RE: cam retard 1999 blazer
Should give you some ideas on what you can try to reduce the possibilities of preignition (ping).
Old 04-28-2008, 07:00 PM
gscrippler's Avatar
Thanks, I will take a look at each item suggested and if no change will bump up the octane to 89
Old 04-28-2008, 09:41 PM
Keep us posted!
Old 04-28-2008, 09:46 PM
Try your local dealer or local muffler shop.
Old 04-29-2008, 10:24 AM
gscrippler's Avatar
Gave the EGR Valve a good cleaning, Throttle Body, and Air intake sensor were also cleaned.
Ping is gone and overall throttle responce has improved, Also replaced EGR gasket with the one
with the screen in it to break up Carbon. Thanks for the Tips. My truck is a 95 replaced motor at 200000 due to a bad valve guide making it skip at idle, Tranny has 282000 miles on it still performs fine exept for if I shift into reverse it shifts hard, Any advise on that issue? Tranny shifts fine in all forward gears no slipping or hesitation.
Thanks Again
Old 04-29-2008, 10:58 PM
cagillman is an unknown quantity at this point
you might want to try a hotter spark plug. or even a platinum type plug. this worked for me in a small block chevy w/ carb
swartlkk
09-22-2012 05:30 PM
samuknow
06-03-2010 12:13 PM
96chevblazer
03-30-2009 06:10 AM
dogz46
11-06-2006 02:31 PM
trkyhntr
08-25-2006 02:44 PM
Quick Reply: Engine ping
