| mr.vls |
11-11-2009 12:51 PM |
Engine Rattle Suspect Spun Bearing
I have a rattle coming from the rear of the engine. I have replaced the CAT and had a trans shop inspect the flex plate and no problems there. The exhaust is tight. The noise is a rattle and not a knock along with a high pitched whine under load. I am looking for ideas. If it is a spun bearing can I pull the engine and just replace the bearing? I am going to take it to my local mechanic for a diagnosis. It is not the drive train or wheel bearings because it will rattle while the car is stationary. This is a 2WD S15 Jimmy and to remove the oil pan the engine has to come out. I have everything I need to remove the engine I just want to know if it is worth a try to remove the oil pan and just replace the suspect bearings.
