engine stalls
Old Oct 2, 2008 | 11:22 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: engine stalls
I got a Help!/Dorman FPR from AutoZone for something around $40, if that helps.
Old Oct 2, 2008 | 11:42 AM
sbhoney's Avatar
sbhoney is an unknown quantity at this point
So you dont need to replace the whole unit you can just replace the regulator. That was the difference I saw. Mechanic wants to charge around 500 dollars for this.
Old Oct 2, 2008 | 11:47 AM
Check out Lindertech.com. They have a FPR upgrade kit that allows you to install the 96+ SCFI FPR into the older CPI spider body. To do this, you have to remove the spider. As a result, you should also replace the internal fuel lines.
The job is not all that difficult to perform and Lindertech has a complete kit with a reconditioned injection spider for $300 including the internal fuel lines, upgraded FPR, and all necessary gaskets/o-rings.
Old Oct 2, 2008 | 04:44 PM
Syres1's Avatar
Syres1 is an unknown quantity at this point
I bought and installed a new egr valve today and that did the trick for my truck. I got the egr valve for 102 bucks at pep boys, and put it in myself the bolt on the left side was a bit tricky other then thats, the easiest egr valve i ever exchanged. Now my truck wont stall anymore, but it still shaking at a red light, WHATS UP WITH THAT?
Old Oct 2, 2008 | 05:42 PM
sbhoney's Avatar
Ok new update. I did not replace the fuel pump yet. The mechanic was finally able to get codes out of it. One was for the EGR so he took it out and cleaned it and the second was for multiple missfire. He checked further and found the number 5 cylinder was not firing. Explanes why the truck was shaking when we last started it so he replaced the plugs and wires. Truck fired right up, he had it idleing for about a half an hour and then let my son take it for a drive. My son drove it for about 15 min and once the truck got warm it stalled out again. Sat for about 10 min and I had to pump the gas a few times then it started. Hooked it up to a fuel pressure guage again and it was 58 with key on and 52 with the engine running at 2500 rpm. The pressure did not leak off at all. Still not sure what to try next.
Old Oct 3, 2008 | 05:09 PM
sbhoney's Avatar
Ok Everyone. I want to thank all of you for your help. The truck is now running and sounds good. It turned out it was the regulator.
Old Oct 3, 2008 | 06:43 PM
Syres1's Avatar
you cant just leave like this!!! LOL what regulator, how much was the new part and so on????????
Old Oct 3, 2008 | 09:09 PM
With a CPI engine, the term "regulator" is most commonly short for fuel pressure regulator or FPR as it has been referred to here. Installs have been covered numerous times as has costs involved.
Old Oct 11, 2008 | 07:10 PM
sbhoney's Avatar
Sorry it took so long to reply. Was on a cruise to Bahamas. Well one week has passed and truck is still running fine.
It was the fuel regulator that is attached to the spider. Part only cost 40 dollars. Until someone on here gave me advise I thought you had to replace the whole spider but you can just replace the regulator if you see no leaks. Turns out that was my whole problem. To bad it took spending 450 to find this out.
gpr13902
Feb 21, 2008 12:23 AM
joeazevedoiii
Nov 23, 2007 05:35 PM
Blindthieves
Oct 12, 2007 09:29 PM
FoxRodder
Aug 27, 2007 09:52 AM
Roma
Jun 18, 2007 03:04 AM
