engine swap for a 02 jimmy from a blazer
hey guys, i have an 02 jimmy with a blown enigne. i have been trying to look online for a different engine to swap it with. i ended up finding a 04 chevy blazer engine with 106k. my question is will this engine work in my jimmy if i swap it out?
it should
Originally Posted by AndrewO1991
(Post 597583)
it should
anyone else before i buy it? |
keep the '02 till you're done - IF anything it'll be a small detail and likely still working on the '02, just swap it over to the '04. The big bad parts that get blown like the heads, crank, pistons etc will be the same so you'll be fine there.
if yours does not have the egr system it is a direct swap, is it does then you will have to swap lower intake, exhaust manifolds and drill/tap knock sensor
i know my jimmy has a vin w and the 2004 engine is a vin x
i have been reading online about this, and it seems like there is a couple things that are different. but sound like it is almost the same engine. sounds like it should swap easy anyone swap to an x and have any problem that i should know about?? |
| All times are GMT -5. The time now is 08:28 AM. |
