engine swap ?
i have a 87 blazer 2wd with a fried 2.8 was thinking about doing a 350 swap,i would like to go carb, will i have to change the fuel pump/tank?do i need to get aftermarket motor mounts,will the driveshaft work or will i need to get it shortened? its just going to be a daily driver for now. i appreciate any advise you guys have. thanks.
RE: engine swap ?
check out http://www.jagsthatrun.com/ everything you need to know about a v-8 swap
RE: engine swap ?
Problem is the 2.8 is a different engine setup than the 4.3. The reason everyone goes for the 350 is because it bolts right up to a 4.3 truck.
Pretty sure from the 2.8 platform, the direct swap is the 305 v8. To go with a 350 you need a new transmission, and I have no idea if the mounts will even match up with the engine and tranny.. |
RE: engine swap ?
the bolt pattern for the bellhousing differs between 2.8 and 4.3. The 305 and 350 are physically identical except for the bores. so if you have a 2.8 truck you need to get a new trans and driveshaft. the jagsthatrun website is very helpful. good luck with your swap
RE: engine swap ?
ORIGINAL: flip469 the bolt pattern for the bellhousing differs between 2.8 and 4.3. The 305 and 350 are physically identical except for the bores. so if you have a 2.8 truck you need to get a new trans and driveshaft. the jagsthatrun website is very helpful. good luck with your swap |
RE: engine swap ?
Ah...ok. So which engines bolt right up to a 2.8 in the v8 persuasion?
RE: engine swap ?
You are pretty much limited to the 3.4L swap that is all so common. It really is a direct drop in swap (well, depending on original and swap induction systems that is).
RE: engine swap ?
thanks a lot guys, i checked out the jtr site looks like they got it downpretty good,if you have any more ideas let me know. thanks again.
RE: engine swap ?
ORIGINAL: WolfPack Ah...ok. So which engines bolt right up to a 2.8 in the v8 persuasion? |
| All times are GMT -5. The time now is 11:56 PM. |
