engine swap ?
Old Dec 25, 2008 | 07:04 PM
ncblazer's Avatar
ncblazer is an unknown quantity at this point
Default engine swap ?
i have a 87 blazer 2wd with a fried 2.8 was thinking about doing a 350 swap,i would like to go carb, will i have to change the fuel pump/tank?do i need to get aftermarket motor mounts,will the driveshaft work or will i need to get it shortened? its just going to be a daily driver for now. i appreciate any advise you guys have. thanks.
Old Dec 25, 2008 | 08:20 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: engine swap ?
check out http://www.jagsthatrun.com/ everything you need to know about a v-8 swap
Old Dec 26, 2008 | 09:13 AM
WolfPack's Avatar
Problem is the 2.8 is a different engine setup than the 4.3. The reason everyone goes for the 350 is because it bolts right up to a 4.3 truck.
Pretty sure from the 2.8 platform, the direct swap is the 305 v8. To go with a 350 you need a new transmission, and I have no idea if the mounts will even match up with the engine and tranny..
Old Dec 26, 2008 | 05:50 PM
flip469's Avatar
flip469 is an unknown quantity at this point
the bolt pattern for the bellhousing differs between 2.8 and 4.3. The 305 and 350 are physically identical except for the bores. so if you have a 2.8 truck you need to get a new trans and driveshaft. the jagsthatrun website is very helpful. good luck with your swap
Old Dec 26, 2008 | 07:33 PM
ORIGINAL: flip469
Yep, the 2.8L is a 60* v6 which represents the angle between the cylinder banks. The 4.3L and the v8s (305, 327, 350, etc) are 90* V engines which have a larger bell housing bolt pattern.
Old Dec 26, 2008 | 11:28 PM
WolfPack's Avatar
Ah...ok. So which engines bolt right up to a 2.8 in the v8 persuasion?
Old Dec 27, 2008 | 03:55 PM
You are pretty much limited to the 3.4L swap that is all so common. It really is a direct drop in swap (well, depending on original and swap induction systems that is).
Old Dec 28, 2008 | 09:44 AM
ncblazer's Avatar
thanks a lot guys, i checked out the jtr site looks like they got it downpretty good,if you have any more ideas let me know. thanks again.
Old Dec 30, 2008 | 12:47 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
ORIGINAL: WolfPack
no V8 will bolt up to a tranny from a 2.8 engine
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
