-   -   engine swap (https://blazerforum.com/forum/engine-transmission-35/engine-swap-29333/)
skidderking 04-03-2009 04:16 PM
engine swap
:confused: Hi everyone, I have a 2000 2 wheel drive blazer with a 4.3 v-6 and I need to know if I can replace it with a 4.3 v-6 out of a 2000 blazer with out having to change the oil pan or any thing else? your help would greatly be appreciated. thanks.
rriddle3 04-03-2009 06:19 PM
If they are both 2000's with 2WD and the same type transmission and rear differential, I think it would be a direct swap.
skidderking 04-03-2009 09:40 PM
my mistake, I forgot to add that the engine was coming out of a 4 wheel drive vehicle.
swartlkk 04-04-2009 03:48 PM
There are no differences in the engine block. Oil pans can be swapped while both engines are out if there are differences in that regard.
josh05 04-25-2009 03:01 PM
there is a difference in oil pans from a 4wheel to a 2wheel drive and the oil pump pickup is different to
xmradioguy 04-25-2009 03:34 PM
yeah just swap the pickup and the oilpan I have done it before.
