engine swap
so right now I have a 99 blazer with a ruined body. im wondering if I can put the engine from the 99 into a 95 model? anyone that has any advice it would be appreciated
sure if you take the computer and all with it. the 95 models had different type of fuel injectors than the 99 does.
It would be more of a hassle than it is worth. Seriously... The 98 PCM is tied with the BCM, and several other serial bus communications modules in the vehicle. Swapping it over is anything but simple.
