-   -   Engine Ticking NEED HELP! (https://blazerforum.com/forum/engine-transmission-35/engine-ticking-need-help-69589/)
red06sc May 4, 2012 11:25 PM
Kinda reminds me of my problem. Only difference is mine is very random. So random that i cant track the noise down. https://blazerforum.com/forum/2nd-ge...-lifter-61135/
94tahoe95lt May 27, 2012 12:16 AM
still in the process of piecing my blazer back together however I have come to the conclusion that the problem may have been a stretched out timing chain which when pulled apart my chain was extremely loose dont have truck fully together yet but that may have been my problem once I drive it ill let you all know if that fixed my problem
94tahoe95lt Jun 3, 2012 02:54 AM
well installed the new timing chain and gear and still same problem will still update on what the REAL issue is if I don't give up and sell the truck.
red06sc Jun 3, 2012 03:05 AM
did u replace the lifters?
evomat Jun 10, 2012 02:49 PM
ive done all the above except timing chain.new lifters,new distrbuter (on way) .checked EGR.it rattles. new intake gaskets etc ...check timing ( a timing light will not work). have to hook up to a computer to check and adjust or get lucky and loosen dist. and try doing a manual adjustment. i have read on here that it can be done . look under diagnostic codes P1345. have not tried the spark plugs but i will
94tahoe95lt Aug 9, 2013 02:56 AM
Thought I would finally give an update it was a lower engine noise probably a spun bearing didn't have time to repair or replace the engine nor could I afford to have someone do it for me so I sold the truck thanks for the help.
