Engine won't start...
Old Jun 29, 2011 | 05:33 PM
Mike89's Avatar
Mike89 is on a distinguished road
Default Engine won't start...
Hey everyone, sorry in advance if this is already out there, I did search before I posted this but didn't quite find what I was looking for.
So I have a 96 Blazer that won't start on it's own, but if I pour a little gas in the the top of the throttle body it starts right up and will run well until you turn it off, then its the same old story.
The fuel pump was changed about 2 years ago, the fuel filter was changed within the past 6-8 months. New plugs, dist. cap & rotor, alternator & battery; ign coil tests out fine too. Fuel pressure reads about 50psi with the key on/engine off and flickers around 48-52 with the engine running. I've got an idea what the problem is but I would like to hear your ideas. Thanks for the help,
Mike
Old Jun 29, 2011 | 10:06 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Do some searching here, sounds like u have a failing fuel pump to me!!!!i believe that the 4.3l needs 60lbs of pressure @ idle
Old Jun 30, 2011 | 05:01 AM
Mike89's Avatar
Ok thanks, that's what I think too, I was just hoping someone had some other thoughts that wouldn't involve dropping the gas tank!
Old Jun 30, 2011 | 01:26 PM
JustJerry's Avatar
JustJerry is on a distinguished road
Sounds like fuel pump, that is the way mine did, only I used starting fluid.
Old Jul 3, 2011 | 09:58 AM
Mike89's Avatar
Hey guys, I spent the day replacing the pump and it solved the problem! Thanks for your help, the pressure now holds steady around 55 with no flickers and the car starts like a champ.
Old Jul 3, 2011 | 10:37 AM
xgiovannix12's Avatar
check in here you might find your problem
https://blazerforum.com/forum/tech-a...e-first-30093/
Ohh nvm you fixed it ! good luck then ! =)
Old Jul 3, 2011 | 11:06 AM
chris015's Avatar
Mike,i hope you purchased a delphi or ac delco pump. or you'll be back in it soon. These things are PICKY on fuel pumps.
doccheese
Dec 12, 2014 03:43 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
