-   -   Engine wont start after lower intake gasket replacement (https://blazerforum.com/forum/engine-transmission-35/engine-wont-start-after-lower-intake-gasket-replacement-96666/)
vetplus40 04-09-2018 06:38 PM
I was so hoping for a bit of luck after changing the lower intake manifold gaskets on my 03 Blazer but no such luck.........:( She doesn't even act like she wants to start. No spits, sputters or anything. If I turn the key on, I have pressure coming out of the the schrader valve on the test connection, but as soon as the key is turned off, the pressure disappears. I did take the fuel regulator off and inspect it when I did the gasket repair, but it looked okay and I reassembled it in the reverse order that I disassembled it in.
Can defective regulator cause an engine to do what I am describing? I have not tried pouring a bit of raw fuel in the throttle bottle to see if it would start. Have not had time.
Thanks
CWBDDSPC 04-09-2018 07:48 PM
It’s pretty common to install the distributor a tooth or more off, even 180 out... might be worth double checking.
christine_208 04-09-2018 09:03 PM
Ditto regarding the distributor.
I did the LIM gaskets last fall and had the oil pump shaft get turned on me. I had to rotate it back using a really big flat-blade screwdriver in order to be able to get the rotor pointing in the direction it had been before disassembly. There are 13 teeth on the distributor gear so that being off by one tooth is almost 30 degrees.
LesMyer 04-10-2018 08:13 AM
Thanks
Yes it could. Also a leak at the regulator o-ring could also cause engine to flood, no start, and fuel pressure to drop to zero as described (this is with a fuel pressure gauge, correct?). If engine is flooded from an internal leak, extra fuel will not help it to start. Only other place the pressure could bleed off so rapidly is back through the fuel pump when it shuts off. Good luck!
vetplus40 04-10-2018 09:37 PM
Thanks for the replies. I marked the firewall with a sharpie where the rotor button lined up before I removed the distributor. I simply do not see how something could have gone amiss here. But I guess anything is possible.
I have not been able to put a fuel pressure gauge on the vehicle yet, but I seem to remember that the fuel line should hold pressure for a little while after priming the line. My fuel line looses pressure the minute that the fuel pump is no longer running.
This thing will not even act like it wants to even THINK about starting...:)
vetplus40 06-04-2018 06:24 AM
Just returned home and back at it. I primed the vehicle with raw gas and it ran fine for a brief period until the fuel ran out. This tells me that the timing is correct.
My guess is that it is either in the o-ring stack or the fuel pressure regulator. Can the fuel pressure regulator be checked?
christine_208 06-04-2018 09:26 AM
Have you done a fuel pressure line check? You can borrow such a tool from autoparts stores. This will tell you if pump is working and if the system can hold pressure.
vetplus40 06-04-2018 11:41 AM
The fuel pump is okay. The supply line won't hold any pressure and I don't have any leaks. The only thing that I have left to check is the fuel pressure regulator.
