-   -   Evacuate trans fluid through filler tube? (https://blazerforum.com/forum/engine-transmission-35/evacuate-trans-fluid-through-filler-tube-96519/)
GreenBlazer2002 03-18-2018 11:14 PM
Ok so I've ordered the shift solenoids, the filter, and the pan gasket. I'm going to be on my back underneath this thing. I would rather not take a bath in trans fluid if I can help it. I'm wondering if it's possible to evacuate the fluid through the filler neck. Seems like it would work. Anyone done this?
Transman304 03-20-2018 06:18 AM
1 Attachment(s)
Use it just about everyday.
Attachment 36288
GreenBlazer2002 03-20-2018 01:48 PM
Attachment 36288
Excellent!! Thanks!!
Strangerock 03-21-2018 06:17 AM
I used to put a small hole in the pan and then braze it up afterwards , no mess at all.
GreenBlazer2002 03-21-2018 07:28 PM
I was considering pulling a pan from the boneyard and making a drain hole in it. Then just swap it out when I do the service.
GreenBlazer2002 03-21-2018 07:44 PM
https://cimg3.ibsrv.net/gimg/blazerf...648052087d.pngHow about this for evacuating the trans fluid?
what size hose will fit down the fill tube?
