Extremely fast idle when cold
Old Feb 18, 2009 | 11:15 PM
3D_Illustrator's Avatar
3D_Illustrator is an unknown quantity at this point
Default Extremely fast idle when cold
I have a 2000 Blazer 4.3 that has been going into a very fast engine idle when cold starting. Placing the truck in gear will accellerate it to about 25 mph without thoching the throttle. When warm the truck operates OK. I live in Wisconsin with cold temperatures of about 20 degrees.
What can I do to fix the problem?
Old Feb 19, 2009 | 10:47 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Extremely fast idle when cold
What rpm is the fast idle? Also does it do it every time you start or only sometimes?
Old Feb 19, 2009 | 12:04 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
If it's below 1200 rpm, i wouldn't worry about it as long as it drops down once it's warm.
Old Feb 27, 2009 | 11:53 PM
This morning my wife said that the engine was turning about 1500 RPM until warm. She had to hold her foot on the brake to stop the truck from accelerating out of the driveway.
Old Feb 28, 2009 | 12:45 AM
AJBert's Avatar
I wouldn't worry about 1500 RPM when its 20 degrees out. That's not too far off from being normal at 'normal' temps.
Old Feb 28, 2009 | 09:49 AM
RWRIGHT's Avatar
RWRIGHT is an unknown quantity at this point
i have a 1995 blazer and when its cold out it goes to about 1200-1300 rpm its just the sensors tellin the motor it needs to warm up...whether its warm or cold i still have to hold my brake in otherwise it will take off not very fast at all though
Old Feb 28, 2009 | 10:21 AM
Does it drop back down to 500-700RPM once it is warmed up?
It should not require holding the brake once you put it into gear though... Have you cleaned the throttle body, specifically the IAC (idle air control) valve and the bore it fits into?
JasonGoneFishing
Dec 11, 2014 08:14 PM
MattyMatt
Nov 4, 2009 05:27 AM
deadeyeden
Feb 16, 2009 08:20 PM
xjoffroadboy
Jan 22, 2009 11:58 AM
shawn_dh
Dec 16, 2007 06:11 PM
