First car maintenance questions.
So I got my first car the other day, the car being a 1996 GMC Jimmy two door 4.3l v6. I know the basics is checking the oil and probably only changed a cars oil once with a friend. It's well due for a oil change. So it'll be easier to list the questions I have I guess. Also thanks in advance.
1. Should I switch to a synthetic oil? 2. What any better brand of oil filter compared to another? 3. What's the best oil brand to use and should I stay using a 5w30 oil? 4. Should I use any additives after I change my oil? 5. What is Marvels Mystery Oil? My friend talked about it before awhile back. 6. Any other recommended things I should do? Like I said thank you in advance for helping me out. |
5W30 always.
Congratulations on your new jimmy. Personally, I'm a fan of full synthetic oil. 5w 30 My reasons are that it lasts longer and more importantly I've witnessed less "stuff" on the magnetic oil drain plug.
The only additive I've ever used is a silver can called "engine restore". There are videos on you tube of compression tests before and after. It works well in higher mileage engines. Marvels Mystery Oil has been around forever and has a large following. Like the hot sauce commercial. "They put that bleep on everything." The other thing is correct any check engine lights as soon as possible. Most auto part stores will run your codes for free and search them here for the best possible fixes. Welcome to the forum. |
Originally Posted by Rusty Nuts
(Post 652312)
Welcome to the forum!!
1. Should I switch to a synthetic oil? Full synthetic is generally thought of as best, but is significantly more expensive. Synthetic blends are thought of as high quality but at a lower cost. Even conventional oils must still meet SG oil specs for content and performance. Synthetics can save you a few tenths of a MPG in gas mileage. Full synthetics are know to retain their properties longer than conventional oils, but then again why not just change it and put in fresh clean oil sooner. I suppose full synthetics are really good for people who forget to change their oil. It's really up to you and pretty hard to go wrong with any major brand oil as long as you get 5W30. Lots of opinions here. 2. What any better brand of oil filter compared to another? WIX 51036 (for 4WD) is known to be one of the best due to better construction and materials. Any filter that is not cheaply made and is not the cheapest one you can find is generally better. I'm sure the Fram filter you mention is probably just fine, as it is a premium filter by a major filter maker. The Wix filters are a bit more difficult to find, as Walmart/Autozone/Advance Auto Parts/O'Reiley's doesnt' sell them - for them you need to go to a real auto parts store. Wix is traditionally a line of filters for heavy duty vehicles and equipment. 3. What's the best oil brand to use and should I stay using a 5w30 oil? Always use 5W30 in your Blazer. Any major brand of oil meeting SG specifications (on oil label) should be fine. 4. Should I use any additives after I change my oil? If you need additives not included in the oil, then you have a problem. SG oils should work fine in any roller cam engine. 5. What is Marvels Mystery Oil? My friend talked about it before awhile back. Old oil additive that cuts varnish and cleans things up a bit. I'm sure it is just "petroleum distillates". I personally would not use it in my engine. 6. Any other recommended things I should do. With each oil change
Good luck!! |
WIX 51036 (for 4WD) is known to be one of the best due to better construction and materials. Any filter that is not cheaply made and is not the cheapest one you can find is generally better. I'm sure the Fram filter you mention is probably just fine, as it is a premium filter by a major filter maker. The Wix filters are a bit more difficult to find, as Walmart/Autozone/Advance Auto Parts/O'Reiley's doesnt' sell them - for them you need to go to a real auto parts store. Wix is traditionally a line of filters for heavy duty vehicles [/QUOTE] First off welcome to the forum. 2nd in response to the above quote o'reillys carries wix filters readily I only use wix filters in addition to being an employee of the company. But napa premium oil filters are also made by wix just rebranded so you can use that as well. I personally only use Mobil 1 full synthetic and in my experience Walmart has it the cheapest for about 23 bucks a gallon which is more than enough for our trucks. Good luck |
First off welcome to the forum. 2nd in response to the above quote o'reillys carries wix filters readily I only use wix filters in addition to being an employee of the company. |
Originally Posted by esquire
(Post 652334)
In the case of Mobil1 full synthetic, everyone appears to sell in 5 quarts jugs. Walmart is $24. Advance Auto is $38. O'reillys is $37. A very good example of a direct comparison! http://www.walmart.com/ip/Mobil-1-5W...5-qt./17034372 http://shop.advanceautoparts.com/p/m...rm=mobil1+5w30 http://www.oreillyauto.com/site/c/de...1188&ppt=C0252 |
| All times are GMT -5. The time now is 10:09 AM. |
