frame mounted fuel pump
I want to replace my in tank pump with a frame mount unit any suggestions as to which one?Stock pump has max free flow rate 60 gph....max pressure range 50 psi...min free flow rate 50 gph...min pressure range 40 psi...it's in a 1995 gmc yukon 4X4 w/5.7 auto ...thank you for your time
| All times are GMT -5. The time now is 10:56 PM. |
