freeze plug?
ive got what looks to be a freeze plug leaking. Its in the front of the engine down and to the left of the water pump on the passenger side. Ive got the 2.8 engine any help would be appreciated.
How good of access do you have to the freeze plug? If it is pretty wide open, then it should be fairly easy to replace. If not, then you will need to remove those things which are in your way.
lonewolfe@mindless.com
Jul 17, 2009 05:17 PM
boulonman
Mar 5, 2007 05:10 AM
