Freeze Plug Behind Motor Mount 95 Blazer
Old Jul 31, 2015 | 01:36 PM
95blazerdriver's Avatar
95blazerdriver is on a distinguished road
Default Freeze Plug Behind Motor Mount 95 Blazer
Is it possible to replace the front freeze plug(s) that are behind the motor mount(s) without pulling the engine? Can you remove the mount and lower/raise the motor enough to get access? Has anyone here ever tried?
Old Aug 4, 2015 | 01:27 PM
abig84's Avatar
ive done that on dodges before. if your truck is 2wd probably be a lot easier without all the 4x4 crap in the way. you can usually take out one motor mount and leave the other one attached if you can lift and support the engine some how. i always replaced motor mounts on these trucks one at a time
C_Ramirez
Jan 10, 2014 07:56 PM
justin12234
Feb 21, 2012 09:16 AM
babyblueblaze
Oct 19, 2007 05:07 PM
boulonman
Mar 5, 2007 05:10 AM
MarkH
Engine & Internal
Mar 1, 2007 06:01 PM
